Bass Blockers necessary?
HeNry2cOoL
When i got my headunit installed at Best Buy they also installed bass blockers in, which they didn't tell me. Since i do have stock speakers in my car and yes i do know they are pos. But it's really lackin on the bass and especially really low bass. I used to get more stronger bass when i had my discman/tape adapter setup on my old stock tape deck before i got my headunit installed. So i'm thinkin whether or not i should remove the bass blockers. I understand that i can run a risk blowing the speakers if the bass gets too strong or to a certain range that my speakers can't handle, but i can always turn down the bass on my headunit.. am i right? And i would've had better use out of the bass blockers if i had some subs, but in my situation i don't and i want a little more bass out of my speakers. So should i remove the bass blockers? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused: Thanks.
[oops my bad, i should've posted this in the Subwoofers and Speakers forum]
i had a friend that this happened to. they just kinda slipped them in with out telling him. he had them put in the head unit then he went out and bought speakers to replace all his factory ones. after all the replacements were in we both noticed it sounded like crapola. the highs were nice, but there was no bottom end at all. ( he has an old altima, 6*8 in front and 6.5 in back) i went over to his place and looked at the way best buy put in the hu and saw the blockers. after i cliped them and rewired, the car sounded soooooooooooooooooooooooooooooooo much better. (until the doors started rattleing) (dang nissans) i understand the use of blockers if u need to restrict the freq. running to speakers, but when u have full range spkrs. (2,3,4 way) you really dont need them. just tune them in using your HU, equalizer, cross over... just listin to your system, adjust it to meet your needs, an replace your factory spkrs.
hope this helps.
Im with budgethq ...
if you get rid of the cap's it's more than likely the sound will be too much for those little buggers....distortion and rattling is way worse than less bass. Get a cheap 8" sub if you want a little more bass. An amp and 8" could run as little as $150.
good luck
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
HeNry2cOoL
HeNry2cOoL
Bay Area, CA
joe_nigga
vegang
vegang
