Basics on home amplifiers
mabel4life
Frank the Tank
Well, I am completely in the blue when it comes to home audio and was wondering how home amplifiers work. I had some old subs and some mdf laying so I made a box for one of the subs with the intentions of using it for some music around the house or in the garage when i'm working on whatever. Could someone tell me all the connections that need to be made on the amp and what else I would need to get this ball rolling. I also have some speakers laying around so i figured i would just get a 2 channel amp and run the two together. Maybe around 400 watts.
I know its possible to hook an amp up to a laptop. What would I need to do this? Thanks.
A plate amp is generally used only for subs, it has a built in lowpass filter which makes it very convinent for sub use. A rack amp has no built in crossovers so if you chose to use a rack amp you have to have an external crossover for you sub. One can generally be had for a little under 100 bucks. Rack amps also use XLR jacks normally, along with the pro-audio crossover units so you have to buy different cables and converters to go from XLR to RCA and vice versa.
For a basic use, a plate amp is the way to go.
A rack amp will be more powerfull as a rule of thumb, but a plate amp is very convinent. In home audio you usually don't need gobs of power like you do in a car environment.
What sub and what impedance are you thinking about using???
Also, are you going to be having some full range speakers also? Because if you don't it is going to sound like anus just having the sub-woofer...
the sub is a cheap one i started out with when i first got into car audio. it was collecting dust so i just decided to make a box for it. it's a 4 ohm sub. i do have two cheap 4.5" inch speakers also. i wanted to get a two channel amp and run one of them along with the sub. im assuming plate amps are only mono, so i was a little dissapointed when i found that out. this was something i only wanted to drop around $130 on, but that looks far off at this point. i dont want to drop alot of money on this because the speakers are cheap and they will also be used outside and in the garage. i wanted to use this as a stepping stone for when i actually get a nice ht setup.
mabel4life
Frank the Tank
mabel4life
central PA
joetama
