Banda Viking 5k
adrum96
Banda Viking 5000
Straight From Banda's Website
1 Ohm Stable (nominal)
5000w 1 ohm / 12.6v
3600w 2 ohm / 12.6v
6700w 1 ohm / 14.4v
4300w 2 ohm / 14.4v
Class of Operation: Class D Full Bridge
Frequency Response: 25Hz to 8kHz
LED Clipping Indicator on the Amp
Average Musical Current Draw: 400A
Protection Circuitry:
Reverse Supply Polarity
Output Short Circuit
Supply Voltage Limit:
> 12v (Recommended)
> 10v (High potential for damage under 10.0v)
Dimensions: 17-11/16 x 10-5/8 x 2-3/8
9/10 for cosmetic because the amp does have slight damage on the mounting feet from being mounted. There are also small scratches on the amp just from use. Originally bought locally from adulbrich and has never been ran below 12.6v. I am also including a RCA 2 female to 1 male splitter because the amp only accepts one RCA input, and I won;t be needing it anymore.
$650.00 Shipped to the Lower 48
Included
Just keep the 5k and use it on your next setup, lol.
Turn the gain down and be easy on the volume knob //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yea over 5k rms to a single 10? I'll tell you how that goes haha
Ok. What was issues people said taramps had ? Was it to much voltage kills them or something I don't remember. Are they temperamental ? I'm looking for a nice amp to replace my current one. If I'm wording this wrong I apologize in advance.
I'll just run it at 8 ohms haha
Yea, can do that too
Don't give them over 15.5v
also don't mount them to a box without vibration-dampening. They have one large power supply, instead of many smaller coils. This makes them more likely to rattle off the board.
I ran this amp at 15v no problem. Highest it saw was 15.2v.
Zero issues and a solid amp
The only thing you really can't do with these amps is run them below 1 ohm. If you're at 1 ohm and keep the voltage above 12.6v (which isn't hard with this amp) it will perform perfectly.
adrum96
adrum96
Springfield, IL
adrum96
