stangman67 10+ year member
well double check that , otherwise I don't see what the problem could be unless the motor got demagnetized somehow
gain is set to nom, tried setting to master and singlewell double check that , otherwise I don't see what the problem could be unless the motor got demagnetized somehow
top plate shift? bottom plate shift?How is the motor going to shift without cracking the basket //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
http://images.cardomain.com//products/ori/ORI27306_1.jpg
The entire motor doesn't move; the motor core gets knocked loose from the epoxy that holds it in, and it pinches the voice coil and locks it in place. I bought a pair of Orion XTR Pro 10" subs in a ProBox a couple of years ago from a guy at work. The box had been dropped and shifted one of the motor cores. The sub looked mint, absolutely not a blemish on it, but I could have walked on that cone and it wouldn't have moved. Magnetic force really works against you when that core shifts.How is the motor going to shift without cracking the basket //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
