backed or non-backed carpet... That is the question
The type of carpet you use depends on a few things. One main thing being your ability to wrap and seem carpet. Different methods of "seeming" or actually hiding them in some cases, will require different types of material.
I seeeee... Well I have a super simple box to cover. No crazy curves or fiberglass, just 90 degree wood angles. And I was going to use this method:
In the video the guy suggests avoiding non-backed carpet at all costs, however, bcae1.com suggest to avoid rubber backed carpet. I'm definitely confused lol
I like backed. The stuff I use has some kind of backing that is clear, almost like one side of it is sprayed at the factory with some kind of glue and let dry.
I dont like the thick rubber backings.
That's a pretty **** box you got there! I might try that next time. Unfortunately, I've already built mine
---------- Post added at 11:47 AM ---------- Previous post was at 11:46 AM ----------
Haha really? You can't say S-E-X-Y?
you could always add the lip to it to be just like his by cutting 1/2" strips of MDF and gluing them onto the edge of the enclosure.
I use non backed, and I buy it by the 50 yard roll.
1/4" inset makes it easier to carpet for sure. You can also rabbit cut the sides to hide the seem in there. I find that they are all a bit easy once you do which ever method a few times. The method in the video works great if you have basic carpet. If you get any colored carpet then forget it, it won't work like that.
HomeLite
HomeLite
Esparto, CA
CAT MAN
