b-quiet?
yo i was aldo looking at the edead stuff and its a little bit cheaper... has anyone heard the difference between the two? which ones better? and also which modles work the best?
b quiet is terrible, the guy who sells it here even refuses to use it,
he uses cascade audio v blok...as soon as it gets hot out it will fall off
regardless if you use a heat gun to put it on...brown bread is good...
well how about edead? i know the v.1 isnt out yet but they dont seem that bad and are a little cheaper than b-quiet.... and what is cascades website?
I went and poked around in my trunk where I had installed some B-Quiet Extreme. The instructions say you can apply it w/out cleaning the surface, and this is a big no no. It doesn't stick well to anything, especially the metal (duh). The stuff I put on the clean dynamat and metal is sticking just fine, although not quite as well as the dynamat. If I were to attempt to pull up the B-Quiet, with some doing I could probably take off entire pieces leaving little on the car. The Dynamat is more difficult to do this with.
ok thanks
another florida member!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The first thing you should do is double-check all of your wiring connections. Usually when people come to me with this issue it's a loose ground...
840
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
954
Daniel
Caraudio.com
Daniel
SFLA
Daniel
    May 12, 2024
Brendon Jenness
    May 11, 2024
