B&C 6PEV13 6.5 Mids and B&C DE35 Bullet Tweeter LOUD!!!!!!!!!
siviog1
Team Bass in Your Face
Hey guys I decided to run (2) B&C 6PEV13 6.5 Mids and (2) B&C DE35 Bullet Tweeter in each front door. I plan on purchasing a active Headunit to tune the system. Can anyone tell me what range or xo point I should run to these speakers? Also I need to purchase an amp for these speakers would someone please recommend an amp as well to power this.
Thanks
B&C 6PEV13 SPECS
Nominal Diameter 170 mm (6.5 in.)
Nominal Impedance 8 Ω
Minumum Impedance 6 Ω
Power Handling
(300-3000 Hz)
Nominal1 120 W
Continuous Program2 240 W
Sensitivity (1W/1m)3 99 dB
Frequency Range 150-8000 Hz
Voice Coil Diameter 38 mm (1.5 in)
Winding Material Aluminium
Former Material Fiber Glass
Winding Depth 7 mm (9/32 in)
Magnetic Gap Depth 6 mm (1/4 in)
Flux Density 1.4 T
Thiele & Small Parameters4
Fs 126 Hz
Re 5.2 Ω
Qes 0.39
Qms 4.6
Qts 0.36
Vas 6 dm3 (0.21 ft3)
Sd 132 cm2 (20.5 in2)
η0 3%
X max ± 0.6 mm
X var ± 1.5 mm
Mms 6 g
Bl 8.2 T·m
Le 0.6 mH
B&C DE35 SPECS
Nominal Impedance 8 ohm
Minimum Impedance 7 ohm
Nominal Power Handling (1) 25 W
Continuous Power Handling (2) 50 W
Sensitivity (1W/1m) (3) 108 dB
Frequency Range 3.5 -18 kHz
Recommended Crossover (4) 5 kHz
Voice Coil Diameter 32 mm (1.25 in)
Inductance 0.1 mH
Diaphragm Material Mylar
Flux Density 1.3 T
You'll probably want to cross around 3k with steep slopes on both drivers, 24db/octave for simplicity's sake. Power look for 200 watts at four ohms give or take a little bit for the mids. Tweets won't matter, your gains will be most of the way down no matter how small the amp is.
siviog1
siviog1
CHi-Town
JL Audio
