Avital 2100 wiring diagram
ok so I looked at the module. It has the main connector, 1-2 prong to the left of it that has the led plugged in, an empty 2 prong to the left of that, and a 3 prong to the right of the main one that is empty.
The 3-pin plug is the lock/unlock. The green wire would go in the pin nearest the main harness, the blue wire would be in the far pin. The center pin is a 12v constant output that works with the Directed lock relay module.
The empty 2-pin plug is for the Valet switch.
As KaeZoo said, the three pin is your lock harness. Usually you plug a 451m into it, then just ground out or send 12volts to the purple wire(whatever you need for your locks). You can pick them up cheap, or I could send you one if you want... i have a bunch in my box at work.
I was just about to ask about what harness I needed. I found them on ebay during school, but they wount allow me to log on. 99 cents on ebay plus $6 to ship.
93 saturn sl2
93 saturn sl2
Michigan
93 saturn sl2
