Avionixx Amps?
I have the same amp. Have you tried resetting the amp? if you dont know how here. This works on the avionixx i know for sure since i have done it on mine.
While the amp is COMPLETELY disconnected from both power and ground you need short those 2 terminals. Its easy just grab any piece of wire and put 1 end on the pos and the other on the ground, on the amp terminals. This will reset it. then hook everything back up and see //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, if the power supply is bad, almost all of them can be repaired... just a matter of how much you're willing to spend.
There have been a few threads on here about amplifier repair, lots of places out there that do it... run a search for amp repair and see what you come up with.
Good luck, maynard.
Good luck, maynard.
Thanks man, I will.
BALDEAGLE57
Banned
BALDEAGLE57
SAN BERNARDINO, CA
linus73
