audison srx4 60 x 4 cheap!
  • 6
pickup1
Polk City Fl
Item(s) for Sale: SRX 4 - Audison 4 Ch 340 Watt Amplifier
Item(s) Description/Condition: used,decent shape,works great and sounds even better.
Front/rear or front/sub amplifier with built-in crossover. Front channels filter can be hi-pass or full range, rear channels one can be hi-pass, lo-pass or full range. SRx 4 can be used as a 4/3/2 channel amplifier. When you choose 2 channel configuration (left/right), you can use hi-pass, lo-pass or full range functioning. There are 'speakers-in' front/rear inputs and a bypass output.
RMS Outputs:
4 x 60 Watt at 4-ohms
4 x 85 Watt at 2-ohms
2 x 60 + 1 x 190 Watt at 4-ohms
2 x 85 + 1 x 170 Watt at 2/4 ohms
2 x 170 Watt at 4-ohms
Bridgeable 4 / 3 / 2 Channel Output
2 Ohm Stable
High Level Speaker Input
Built in Cooling Fan
High Pass Crossover
Low Pass Crossover
RCA Input
Price: 120 shipped o.b.o.
Shipping and Miscellaneous Item Information: fedex or usps
yep,sounds great...found an audiosystem amp i want,so this has to go.i only used it for my tweeters..
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
pickup1
pickup1
Polk City Fl
pickup1
