Sold AUDISON SRx 2S 2 Channel Nice very SQ...
RetroAudioinc
Custom Car Audio Decals
1. Product:
2. Specs:
Product Description
Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC
Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.9 A
Idling current when off: . . . . . . . . . . . . . . 0.002 mA
Musical max consumption: . . . . . . . . . . . . . . . 35 A
AMPLIFIER STAGE
Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.03 %
Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 280
Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V
Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V
Pre In input impedance: . . . . . . . . . . . . . 15 kOhms
Speakers In input impedance: . . . . . . . . . 100 Ohms
LOAD IMPEDANCE:
2 ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms
1 ch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms:. . . . . . 135W x 2
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . 180W x 2
- 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . 300W x 2
- 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 600W x 1
FILTERS/INPUTS
Inputs: . . . . . . . . . . . . . . . . . . .Pre In / Speakers In
Outputs: . . . . . . . .Pre Out (hi-pass/bypass/lo-pass)
Filters: . .12dB-24dB/Oct., hi-pass / bypass / lo-pass
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50÷350 Hz
Lo-pass switch: . . . . . . . . . . . . . .stereo (12dB/Oct)
. . . . . . . . . . . . . . . . . . .mono (24dB/Oct) / bypass
Q control:
(on hi-pass) . . . . . . . . . . . . . . . . . . . . . . . .Q 0.7÷2
OTHER FUNCTIONS
Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA
Connections for VSR kit
for SUB remote volume: . . . . . . . . . . . . . optional kit
Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . . strip, 30 A
Protection: . . . . . . . . . . . . . . . . temperature >85°C,
DC voltage, overload
Green-red LED indicators: . . . . . . . . . . . . on-safety
Cooling fan: . . . . . . . . . . . it activates from 55°C on
MAX SIZE (D x H x L): . . . . . .178 x 49.5 x 440 mm
3. Description/Condition:
Used but in very good condition, detailed photos below.. It is missing the little end caps but does not affect it at all and still looks new..
4. Price: :
$250 shipped
5. Pictures:
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
