audison lrx 1.400
How do you know it's going to over heat? What load are you going to run it at?? A cooling fan isn't necessary unless you're going to be driving the hell out of it.
And drive the hell out of it while it is in a tiny box with no air holes. Audison builds a solid amp. As long as you don't set the gains to the point of clipping, it shouldn't have any problems.
BTW, I would say that close to 90% of the amps out there worth having DON'T have cooling fans. This is for the simple reason that the engineer who designed it spec'd an adequate heatsink for the job rather than trying to make do with and undersized sink and adding a fan as a band aid fix.
i'm gonna run it at 1 ohm. probably for a couple hours each day. i'm not saying it's going to overheat, i'm asking if it is? for $400 you think they could have thrown a cooling fan in that bad boy. seems like a solid amp though, maybe i'll just order it and find out.
If it doesn't need a fan then adding one is pointless and a waste of money. I ran an Orion 250hcca (no fan and Class A/B so much less efficient thus generating more heat) for several years @ 1 ohm without any problems. If a fan was needed for the design, there would be one. It isn't so there isn't.
good point. i'm gonna be properly setting my gains accordingly of course, and i'm not gonna crank up the volume til my ears bleed, so i should be happy with this amp. thanks for the input, now i'm gonna order one.
userdel
userdel
st. louis park, mn
userdel
vegang
vegang
