audioque noise?
Notloud00
Quiet
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif my friends sub all of a sudden started making this mechanical noise. its like it is lightly bottoming out or something but it isnt close to full x max and doesnt do it on lower notes just like 30-48hz or so. we free aired it and it still does it. the sub has never been over warm and has seen around 500rms. it has had about 3 or more hours of play on it. he said it did it yest but failed to mention it to me. the coils are also a perfect 4 ohms. also the coils are a perfect copper color and their is no visual damage anywhere on the sub. is this just break in noise or is something f'd? its an sd 2.5 15
Coils may be out of line?
IT is in 3.85 cubes at 40 hz. fully braced box 1 8.5" sono tube. if we did break it in wrong{i dont see how that could make this noise} then thats fine. the sub plays fine it just makes that noise. i have heard of other peoples doing this to. maybe it will go away once the suspension loosens up fully.
Low notes or high notes?
You should keep the volume down...
What series woofer do you have? i'm assuming SDC2.5 ?
more on the lows. Yes it is a sdc2.5 15. i guess ill tell him to go easier on it for about 2 weeks or so. then i will see if the problem persists.
You shouldn't have been playing them low notes in the first place! The point is not to get the woofer moving at the lower excursions..
Break it in for a bit more on medium volumes, if it doesn't go away, live with it or recone it..
Notloud00
Quiet
Notloud00
Everywhere
MasterOfAllBass
