Audioque hdc3's
actually no it was early this year. subs still strong. never smelled. still competes same sub. it ran for about 2mins 25 secs. again these were sundowns. he stays at 13v. idk. he just has a beastly sub. another teamate of ours had the d1 18 hdc. on 2 aq1200s strapped(2ohm)s...... it funny cus he competed 1 time and and the we hooked it to only 1 saz 2000d and it last 30 secs and the sub was done. ( hes a moron for hookin a d1 sub on strapped amps that only go to 2 ohm tho)
A D1 was the right choice. Wired in series will give you a 2 ohm setup.
As for the HDC3, they work great on 1k daily and even a little more if it is clean power, and you know what your doing. With that said, there are only a few who are doing a real 2k to one HDC. Most think they are but after rise and voltage drop they are not.
with that being said his truck charges @ 14v and never goes below 13v. also he is running a sundown rated 2k at like 12v - 12.5v or some like that.
i really dont see him not getting 2k. he has two volt meters 1 in front at batt and in back right before amp. the amp meter and front stay at 13v. so he should be getting it. plus we strapped 2 sundown saz2k so thats def more then 2k.
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
