Audiopipe must be from aliens
No, its not a volume knob. For the same output from the amp for example. My headunit has 2.5v outputs and the gain is 1/2 then if your headunit has 4v outputs then your gain would be about 1/4 of the way for the same output from the amp. This is just a quick example so don't follow to the T.
Ok that wasn't worded right. I have the gain set by ear right now but obviously i know it's not volume But the gain has to be just over half before the sub is remotely loud. I'm using a stock headunit with a line out converter so I'm pretty sure I'm not over 2 volt pre outs. I know it's almost impossible to recognize audible distortion from a subwoofer but I can tell when it starts putting out dirty power and I back it off at that point
Ok that wasn't worded right. I have the gain set by ear right now but obviously i know it's not volume But the gain has to be just over half before the sub is remotely loud. I'm using a stock headunit with a line out converter so I'm pretty sure I'm not over 2 volt pre outs. I know it's almost impossible to hear audible distortion from a subwoofer but I can tell when it starts putting out dirty power and I back it off at that point
My bet is that the amp like most cheap amps is full of distortion.
check your hpf/lpf on the amp.
that phrase is a paradox
Liquid Bass
Midwest Militia
Liquid Bass
KC Missouri
Wingman0121
