Audiopipe APF1801
It is overrated. I think it is advertising max power.
That amp is rated at 1800 Watts RMS when your subs are wired down to 1 Ohm. As to the fuse rating i believe it is rated between 60 & 90 Amps when you combine the fuses. If you need any more information, please read the listing as it has all the accurate information taken right off the side of the box. And if you need any other help or have any other questions please feel free to ask.
- unique7audio
We posted at the same time. Don't worry about the Dumbass SirSwish. These do rated, 1800rms. Just at least do the Big 3, and try to add a second battery if you can. You should then be fine, and should be able to keep the voltage up.
Hahahahahahah. SirSwish, you are a dumbass. To the OP, these do do rated. They are some of the best bang-for-buck amps, next to the MB Quarts. There are plenty of threads on these amps. This is one on the AP1500, but will give you an idea of the build of the amp/what it will do. http://caraudio.com/forum/amplifiers/354382-audiopipe-ap15001d.html
The ones that do rated are the AP series. The one he is referring to is the APF series which has zero threads on. I asked the guy on ebay who sells them. Now who is the dumbass?
And if the guy on eBay said that they actually did 2200rms, would you then believe him as well?
You are truly a dumbass aren't you? He told me the fuse rating on the APF1801 is somewhere between 60 and 90 amps. You honestly think you are getting 1800 watt rms on 90 amps?
Radrick Davis
Radrick Davis
Goodlettesville, Tennessee
connersdad19
