Audiopipe APCLE-2004 Amp Dyno
I feel they could have come up with a cooler name than "audiopipe", and a piece of galvanized drain line as a logo couldprobably be improved upon as well
good vid. seeing this makes me less likely to buy other audio pipe amps, even if they bench well and seem ok. just not worth saving a few bucks (given there are other solid cheap options as your videos show us) vs buying from a better brand.
also; what are people's opinions on AB vs D amps? i know a lot of real esoteric audio types insist AB sounds better (and that tubes sound best, for that matter), but a lot of the el cheapo stuff is AB, and it seems like it's always bad on electric.
based upon all the negative comments on here about audiopoop, its not a shock that it blew up. Good thing you saved your other equipment, but it would have been nice to see all the glorious magical smoke escape from this beast LoL
Audiopipe has and always will be audiopipe
The apsm1500 does around 1200w and was available for $100 shipped when it first came out
Many people ran it at .5ohm and they worked fine
It was the go to cheap amp a few years back
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
bigblank69
bigblank69
Eureka, MO
tymoto21
saints747
    May 7, 2024
saints747
    May 7, 2024
