Audiopipe amps vs Actual amps :P
Yes, the DSC 1500.1D is the MB Quart Discus series. They are good amps, but I can tell a difference in SQ between my DSC1500.1D and a good quality A/B amp. Just slightly, but night and day better than AudioPoop
the difference from the apsm to the dsc 1500 is about even to the one between the dsc and the saz...
Don't think you can get any simpler than that..Question now is, how much should my budget be for a decent 700-800 watt RMS amp @ 1-2 ohms? I don't want to push my OA15 any farther.. I'm going to assume that a good amp @ 1 ohm is more efficient and sounds better than a 1000 watts coming from an Audiopipe amp @ 2 ohms?
I don't need absolutely high end amps, like SAZ, just something that is good, does what it does, but without paying a premium. Just like OA subs. Awesome quality and price!
$225ish? Maybe some links to amps?
RE Audio is good right? Found this 800 watt RMS amp for $190!
RE Audio DTS-1000.1 800 Watt RMS DTS Series Mono Car Amplifier Amp DTS1000.1 | eBay
Other, possibaly better options perhaps?
Look for one that will do what you want at 2 ohms, if that is what your sub wires to....
Not too sure about that...
APSM " S/N Ratio: >70dB ...Total Harmonic Distortion:
DSC "Signal-to-Noise Ratio 95 dB....THD at Rated RMS Power .10%"
Remember, Audiopoop's specs are exaggerated, or at the very least right on the ragged edge of what's listed. I have heard the amps with the old pipe emblem, AP15001D, and 1200 and they definitely make it sound like you get what you pay for. For $179-199, you can get a lot better amp...
EpicMango
EpicMango
Colorado
VWBobby
