AUDIOCONTROL EPICENTER Need Info on them
crfrider
I was just wondering if these are worth it Also do you have to have the Epicenter Plus also with the Epic 160 to get the most out of them, do they both do the same thing? Or could I just Use the Epic 160, also how do you hook these up,, and do they take the place of your bass remote knob on your amp or can u use both and does it make a bigger difference when you use both remotes also do you use these only for the sub amp or could I use it for the mids and highs thanks
also if I was to get the epic 160 then also get the epicenter 6xS electronic crossover how would I hook these together I have a Kenwood DDX812 how would I run the RCAs to the EPic 160 since there is only one Input and output would I just hook plug the sub RCA into it then how would I plug into the crossover would I run the other Front and rears into it
At this point your best bet is to find an Audio Control dealer or call them directly. They will give you the facts to direct you to the best product for what you are looking to accomplish. You'll get a lot of opinions here but for how many questions you have contacting a dealer or the company directly will give you the best answers.
crfrider
crfrider
Oklahoma
ciaonzo
