Audiobahn
i had that sony xplod amp (1200) on 2 old skool comp kickers and they kick harder than what i got now. I sold the amp but i still got the kickers
Sony is crap as well... I would actually rather run Audiobahn than Sony when it comes to car audio.
Do some research on the products before you purchase them, and you might end up with something worth keeping..
naw i was trying to test my ground, cuz when i turn my radio pass 30 with the loud on, the subs doesn't go any higher just the music inside the car.
Because you have reached the full clipped output capability of the amps. Remember they can't produce a lot of power. They are over rated and you will find them easy to clip.
Set the DMM to AC and put the probes on the speaker terminals.
And I hope you're not testing the AC current for a output measurment...
Good luck getting more than 300 clean watts out of those amps.
Um... ill take "NO" for $500, alex.
If youre testing any electrical system in the car, set it to DC volts... AC is like you fin din your house, and the DMM's i use are very particular about that. If you try to test either the wrong way, it blows a fuse inside the DMM.
Re read what he said. He said set it to AC on the OUTPUT terminals. He is correct. If he wanted to test for voltage at the power/ground terminals then he'd use the DC setting.
trigga_b
trigga_b
chicago
Rsahota112
