Audiobahn
could it be the box, the ones i had couldn't even fit in a regular 12" sub box. its like you had to buy their brand of box or some shit and it comes with instrutions on specific boxes that give different sound quality.
No, it's more than likely no the box. The ones I've incountered had to much mechanical noise.
could some one tell me where the test leads go to check my ground wire from my amp and what it should read, cuz my amp isn't performing to its capabilities unless the amp is shitty.
They normally dont fit in pre-fab boxes because the basket on them is too wide, and wont allow the subwoofer to fully fit through the hole. And no its not the box. I messed around for a few months with an audiobahn sub to try and get it to sound decent (building several different boxes and trying different power configuration) and I never could get a bahn to even sound half way decent.
Subwoofer Specifications
Rec. Sealed Box Dims: .5 - 1.5 cu.ft.
Rec. Ported Box Dims: 1.3 - 3.3 cu.ft
Free Air Usage: not recommended
Sensitivity: 92.7 dB
Frequency Response: 20-500 Hz
Recommended RMS Power: 700W
Peak Power Handling: 1400W
Impedance: dual 4 ohms
trigga_b
trigga_b
chicago
Rsahota112
