Audiobahn A2300hct
apsabr
RiMsSiTlOw
Just saw one of these go on ebay for 350+shipping? was it worth it? i own one of these and use it but if its worth that much or even close to that i wanna sell and buy something better cause i know 200-250 will buy a hell-eva good amp off here. and are these specs right? it actually says its like 4800w max?
4800W Max, High-Current 2-Channel Car Amplifier
RMS Power Rating:
300 watts x 2 chan. @ 4 ohms
600 watts x 2 chan. @ 2 ohms
1200 watts x 2 chan. @ 1 ohm
Bridged:
600 watts x 1 chan. @ 4 ohms
1200 watts x 1 chan. @ 2 ohms
2400 watts x 1 chan. @ 1 ohm
Max Power Output: 4800 watts @ 1 ohm
Wired Remote Bass Level Control Included with Blue Illuminated Knobs
Also illuminates red to indicate when amplifier is clipping
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Input Sensitivity: 200mV - 8V
1/0- or 2-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
Dimensions: 25-5/8" L x 11-15/16" W x 2-1/2" H
Note: Flames add an additional 1" to the height
ya its a decent amp but theres alot better out there for the money thats why im sellin it to buy something else. i sure didnt get hurt in it though i give bout fifty bucks for it
apsabr
RiMsSiTlOw
apsabr
NORTH CAROLINA
apsabr
