Audio System ?
I am currently researching car audio systems for my needs. I would like to know if I should buy 10" subs or 12" subs. The reason I ask is because of the range of music I listen to. I listen to just about everything except jazz and classical on a regular basis. I got a quote for a system today that includes 2 x 12" DVC 4OHM JL audio subs, and a 500 Watt class D Mono Block Amp. Is this going to be sufficient for my needs? The reason that I chose 12" instead of 10" is because I do listen to some Rap/HipHop. I also listen to some country, alot of 80's Rock and Groups like Disturbed. I have the factory speakers for Mid range and Highs.
I apologize if this is not the area to post. TIA... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
We can't say if it will fit your needs because we do not know you nor do we know what you want/expect.
Those subs will be fine playing any type of music. If you're not looking for a ton of bass, I'm sure they will work well.
If you want really quality sound, upgrade your front speakers as soon as possible.
Ishkapiddle
Ishkapiddle
Springfield, Mo.
Immacomputer
