I just installed my 2 amp system and my problem is that the lc6 cuts off at low volume. If I am playing 50% or higher, it doesn't shut off. The sound is excellent, but it shuts off at low volume. The lc6 shuts down and my amps are down because the remote is coming from the lc6 output. The lc6 has a remote coming in from the stock wiring harness. Do I need a better remote source...maybe the cigerette lighter? The manual says the speaker inputs turns on the lc6 but I also used the remote turn on too. What do I need to check ? The lc6 manual says If my stock units speaker signal is too low, I can adjust the incoming signal to low on the diagram but I don't see it on the unit. Do I need to take it apart to adust the signal ?
