Attaching PVC to MDF
Bigger holes = less air resistance. Gorilla Glue sounds good, but I checked this about 30 minutes ago, they aren't going anywhere. If they give ANY after the caulk fully cures, I'll gorilla glue them.
The wait to try my 15"s in a ported box is killing me.
no, what i meant was why do u make the holes so big when u use the jigsaw.
Didn't use a jigsaw. Used a drill with a special bit for making in-home PVC holes, so it was about 1/16 inch too big.
But, here's the update!
**** hell shit **** and other such expletives! This setup sucks. The thing is half as loud as before, bass boost sounds like ****, and it's generally a very unpleasant bass! Oh, what to do.
I went to a local dealer. He brought up the specs for the sub. It want 10.5 cubes PER SUB to be ported. My entire trunk my be 10 cubes. Gah. They also want 5 something per sub sealed. Well, ****. I'm going to lose the ports and polyfill the sucker.
[documentation mode]
To "properly" (heh!) close off the port holes, I used a combination of black fleece cloth, MDF, Caulk, sheet metal, and screws. I first covered a piece of MDF cut to fit in the hole with fleece covered in caulk, then I shoved the entire thing into the port hole. To be sure that this would go anywhere, I cut pieces of sheet metal, and screwed them onto the box and the plug. If I can get a digital camera, I'll take pictures.
actually homie imma show you waht this says right here
http://www.electronixwarehouse.com/car/sgl-prod/speakers/woofers/spl/elf-15.htm
^^ your sub correct ^^?
if it is here look at the specs...
SPL #ELF-15
15" 700 Watt Subwoofer
• 700 watts power handling
• 80 oz. magnet
• 2” kapton voice coil
• Dual 4 ohm voice coil
• Chrome plated basket
• Polypropylene cone
• Chrome front & back plate
• Foam rubber slant surround
• Black spider
• Chrome push terminals
• SPL 93 dB
• Sealed box: 2.5 cu. ft.
• Ported box: 4.25 cu. ft.
• Tuning: 29 Hz
• Port size: 3” (dia) x 3.2” (length)
• # of ports: 1
so i dont know if that guy gave you the total cubic feet and you just thought he said per sub or what. but 4.25 @ 29 hz sounds not too shabby. holla.
I'd seen most of the specs, a lot of those are new to me. Not bad for a 70 dollar 15" sub. The price has dropped significantly since I bought them.
As usual, the local shop was hella off. Some computer program they had with fancy charts and all that.
Anyway, the box is HISTORY. I seriously don't think I can repair it anymore. It's a cheap prefab, and the rest of my cheap equipment is blowing the thing apart. I'm going to get some MDF when I get the chance and just build a new box.
Scarenius
Call me Ravo
Scarenius
Michigan
Scarenius
