Thats a little extreme don't you think mark?I use fiberglass and resin to secure pvc to mdf.
i get where your going with this. thank you sir! thing is ive only built the one, then ran out of wood. lol now the 2 are going to be different!I cut the baffle hole the same ID as the PVC and round it over to create a flare. I cut another piece the same OD as the PVC and glue it to the inside. I do the same for the other end and sandwich the pipe between them, then caulk it. Looks good and holds the pipe secure.
I hear you. I usually use scraps like the baffle cutout to make the inner pieces. You can also use a small piece to glue from the side of the box to the edge of the pipe and use some plumber's strapping to secure it.i get where your going with this. thank you sir! thing is ive only built the one, then ran out of wood. lol now the 2 are going to be different!
