Atomic AP/SPL Build
Hmmm wonder how the Atomic will like that. I've been told that they don't like tuning under 38Hz. Idk though,
I just thought of something though, would box rise cause a lot of trouble?? I don't understand how and what causes it but I know it happens. Could that be a reason why the 20.1 isn't kicking out as much power???
Jon
If you are wired to .5 ohms...you shouldn't be rising up high enough where the 20.1 wouldn't be pulling enough current to slightly dim your lights, especially if your electrical is completely stock. they aren't the most efficient things so they pull a decent amount of current even at a 4 ohm load. How do you have the sub wired...
Should be,
Positive and negative on one voice coil to the amp, and then 2 jumper wires from one coils positive to the other coils positive and one coils negative to the other coils negative.
you need 2.5 - 3.0 cubes for that sub and 38hz tuning. thats optimal space for that sub. ive talked to many people who have used them and they perform best to those specs. thats why i said the box needed to be that size
You might've been better off going with aeroports IMO.Still, not that bad of a build.
Thanks, right now I'm looking into hacking it up and see if I can save it. Shrink it down a little. Hopfully I can salvage it b/c I'm totaly out of MDF, and don't have a lot of cash to go spend on more.
Jon
Jon
Yeah, I hear ya man.It can probably be saved, if you need help throw me a PM.
ok guys, have 2 more favors to ask... I did some redesigning, I shrunk the box down to 3.21 Net, I'm cerious to what the box would be tuned with the existing port (8 x 5 x 21.25) Also what would it take to get a box 3.21 to 38Hz??
I would really apprceate it!
Jon
Thank you very much!!! Thats actully right about were I want it. Here are a couple pics I took of the "rebuild"...
Before
After
I'll take some more as I put it back together. So as of now, the build looks to be salvagable!!!!
Jon
kickerlivinloud
Banning survivor
kickerlivinloud
Finger Lakes, NY
mjf
