At what point is disconnecting battery negative really not that important?
ckunke002
I'm curious what types of installs in particular are important to disconnect the battery. All of the professional websites of course suggest always disconnecting for any install or modification of any kind of anything speaker/sub/amp/electrical related. I recently did the big 3 and I have several connections on my battery terminals that make it difficult to disconnect and reconnect all of the time.
Have you guys ever suffered any bad effects from skipping this step for installs? What is the main thing to look out for if you don't disconnect? Just curious.. thanks
there is a reason that professional installers do it, b/c it saves you from having to trouble shoot later. it's like hot swapping RCAs, you can get away with doing it but when your RCAs start producing noise don't complain about it. if you can't easily disconnect your negative to your battery, you're installing wrong. any decent install should be easily serviceable, that includes easy access to key connections such as your battery.
What kind of battery terminal connector did you use? I have several 0g wires coming off mine and have no problem removing them the connectors? I don't need to remove the wires... just pull the whole thing off the terminal.
What is a hot swap? Lol
I bought a Kinetik 1400 battery... apparently the one I bought was a short lived model called the 1400 black, and featured small bolts instead of posts. The terminals positions were also reversed from my factory battery as well, so I had to rig up all of the factory wires with ring terminals and then stretch to (barely) fit on the + and - terminals. Took like 20 minutes to get it all together.
Yup they all have ring terminals, like that. The biggest problem was the backwards terminals so everything just baarreely fits and it's a ***** to take it off and then try to get it back on. Having all those rings lined up and then screwing the bolt in.... //content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
i got the **** shocked out of me one time in my early install days. I pulled too much power from a 8 gauge walmart kit, and my fuse had melted to the firewall without me knowing it. I put my key in the ignition and turned the car over and blue sparks shot across my dash. Was pretty crazy at night. I thought i was going to die. Just thought i would share a cool story, bro.
But yeah disconnect your battery anytime your power/ground wires are not connected properly
Hey bro, cool story! Lol really though. So you actually got shocked?
In response to the OP.. I dont disconnect my negative cables when working on stuff. Call me a badazz.. but I figure its all off as long as the car is.. just remember what wires are live and what arent.
If your moving amp power or ground, unhook it first. It doesn't take much of a mistake to ruin your day. Everything else I leave it hooked up. But I've also learned from previous mistakes how to go about that.
So is there any difference between disconnecting inline fuse by battery from disconnecting battery neg? Because some people say do both... fuse is a whole lot easier to take out and put back in!
Sort of a thread jack, but i once was out mudding in my truck. Bouncing so hard i broke the crappy battery strap. Batt ends up upside down and welds the bolt for the pos. Cable to the top of my valve cover. That was almost 3 years ago and its still there.
May I suggest using a ground bar with a single 1/0 from battery to the bar? Then all you need to do is un hook at that point and isolate the end from contacting medal Islide my loom over the end then tape up when I need to do this. I had a similar issue but mine was more that the Mini batteries are located near fire wall and did not like being that close to the hood.
ckunke002
ckunke002
Portland, OR
esmokah
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
