Ascendant Audio Build log!
I normally don't comment on builds, but as an avid minitrucker and someone who likes big syststems built well...I have to give this one a huge thumbs up. That cage is nice and a real good idea. Are you planning on doing dB Drag or Bass Race?
Strictly demo/show off what we can do...musical all the way
It's going to be far from ordinary //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It looks absolutely insane! You shouldn't have to worry about box flex at least //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Have you picked up a new headlight switch yet? I used to have an 88 SE-V6 that I loved, **** near bullet-proof. I had problems with my switch too, I bought a new one and it only lasted about a year and a half. They are easy to fix though, you can pry off the cover where the contacts are and figure out which one is for the light you need to fix. Then you can bend it so that it makes a connection, it takes a bit of playing to get right but it will last nearly as long as a new switch. Just make sure you turn it on and off a few times to make sure it's bent right or you could end up with the same problem or the light won't turn off.
Truck and everything you've done looks great so far, keep it up! I'm hoping to jump onto the AA wagon and get a Havoc as soon as I get my bonus at the end of the month, should work well with my Kicker SX1250.1 //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I've worked on it..just haven't taken any pics..
SPAL kit showed up for the windows yesterday, and i've just been sanding and filling on the door panels...nothing too exciting or pic worthy as of yet //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/needpics.gif.edd6d28e76618c28c46f343991bcced5.gif
NDMstang65
Active Noise Control?!
NDMstang65
Radford,VA
TnT_Sounds
