as shitty as it looks...?
RMS Power Range : 1200-1700 Watts Number Of Channels: 1
Maximum Power: 3000 Watts
Low Frequency response: 9 Hz
High Frequency Response: 50000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
WOW, you must get that amp with a 50000 Hz frequency response, you never know when you may need it.
I wouldn't buy it, try finding a deal in the classifieds section.
i'm not convinced the specs are accurate.
for one, its a monoblock. how do you get it to be "trimode capable"?
for second, its a class D amp. 50khz seems to be a bit high for the upper cutoff.
dude its a knock off of "sound stream" i bet you nothings legit
wow, a class D with 50.000 Hz response!!!
as you all know the chip inside has to have a much higher frequency than the output, so i think they have a 150.000hz chip inside WOW.
very impressive since zapcos 9.0 is the only real fullrange digital amplifier out there....(well except ALTO but they use ICs for the output) and they use Tripath so this amp is THE SHIT //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
...well...not at all....
didan
bigt
bigt
USA
DiDan
