i am talking about the fuse.it calls for a 120 amp fuse. but i have a inline fuse holder and i was told the bestes one you can get is 80. then they said ill have to upgrade to a anl fuse
no, an 80 amp will be OK....but if the fuse blow a lot...then u should upgrade. But, u might be able to get by with 80, considering that the amp doesn't run consistently at MAX current draw. peace
ok, got it all going. now should i run a power cable for the crossover or should i just get a inline fuse and tap in to the amps power and if so what size fuse should i use??? the vrossover is a kicker x3i
