Are these amps good?
You did realize that the ratings given for this amp is at 14.4V @40hz right? You will have to ensure that it is seeing that voltage to get anywhere close to that 5K. Are you running on upgraded power? If not, then lessen your expectations on rated power a bit if you're running stock power. It may outperform the Taramps smart 3K, but running them below 1 ohm is not recommended.
Jon91v8
CarAudio.com Recruit
Jon91v8
Los Angeles
Kapet
