Are my grounds ok???
Mike yayo
Chevy Ridin on 24s Ya Dig
My sub amp keeps shutting off at volumes higher than 45 even when above 2000rpms, on hu its at +4 and hpf at 80 hz. someone said my grounds might be the problem so are these grounds ok or should i scratch that black off? thanks sorry for big pics. ones for my seperate batteries and other is for my sub amp the pics.
The only actually grounding you are getting is through minimal contact with the bolt and washer on the other side. I'd take a dremmel to the paint below the ring terminal for maximum connection //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 that should fix all of your problems.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
paint=bad
wow i just scraped all black around it off, and it still will shut off around 45-50 with bass on 2 and hpf on 100hz.
i have a pioneer so its out of 62
its not like i want to go to 62 its just i want to be able to play it around 45-50 area with bass 3 and not shut off.
my setting on colouss are (running at 2 ohms btw)
Amps set like this
Subsonice-Middle
Bass eq-0
Low pass-pointing at like 11:00
Phase- like8:00
Level-2:00
Amps set like this
Subsonice-Middle
Bass eq-0
Phase- like8:00
Level-2:00
How long does it take for the amp to shut off? What kind of car do you have? Sounds like it could be your alternator is going out and your amp is protecting itself or you may need a High output alternator. Well looks like you have an aftermarket alternator. You may want to check and see what the voltage reading is on it with multi meter.
Also what kind of subs are you running? dual 2 ohm dual 4 ohm single 2 ohm or single 4 ohm etc. How do you have them wired? Could be sending amp a load it isn't stable at.
Mike yayo
Mike yayo
tampa
60ndown
