Hi guys,
It seems that 5 channel amps aren't that popular. Is there a reason why? Are there any disadvantages using a 5 channel amp like a Alpine MRV-F450 V12 5 Channel Amplifier?
these are the specs:
- 50 watts RMS x 4 + 200 watts RMS x 1 at 4 ohms
- 60 watts RMS x 4 at 2 ohms + 200 watts RMS x 1 at 4 ohms
- 120 watts RMS x 2 + 200 watts RMS x 1 in bridged mode
- 2-, 3-, 4- or 5-channel output
- Tri-Way capable
- requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
- Bass Engine® features:
- front and rear channels have variable 50-200 Hz high-pass/low-pass crossovers, 12 dB/octave
- sub channel has a 30-200 Hz low-pass crossover, 12 dB/octave
- selectable (15 Hz or 30 Hz) subsonic filter on the sub channel
- tuned Bass EQ (6 dB bass boost at 50 Hz with adjustable Q factor, while frequencies below 30 Hz are cut by 6 dB) on the sub channel
- MOSFET power supply
- STAR Topology (minimizes internal noise and prevents ground interference)
- oversized power and ground connections
- gold-plated screw terminals
- top-mounted controls with cover
- detachable front cover
- blue power LED
- 16-9/16"W x 2-3/8"H x 11-13/16"D (depth is 10" with front cover removed)
- Tri-Way capable
- blue power LED
