Sold Arc CXLR4150- black chrome version
3.5Max6spd
yo mama no wear no draws
specs...
85rms x 4,330 x 2 (review/test shows 100 x 4@4ohm and ~ 366 when 2 channels bridged)
S/N ratio- greater than 105db
THD - 0.005% @ 4ohms
Damping factor 2300
stereo separation 85db
built in fan
Microprocessor controlled
Remote digital bass boost gain w/led status display
Set and forget crossover switches on bottom plate
Seperate front and rear high/low/full range select switch
Seperate front and rear mono/stereo/full range
select feature
Heavy duty construction
Thermal, DC, offset, reverse voltage, over voltage, short circuit protection
* Pulse width regulated power supply allows amp to make rated power(or actual power) as low as 12.5v
3.5Max6spd
3.5Max6spd
Dirty Jersey
3.5Max6spd
