Arc Audio Or Alpine Sub - Arc AMP
konradac
SDCrew
I am finally getting around to redoing my system. (Yay for money)
My AMP is ARC Audio 1500-XXK Amp. (Stereo @ 2 ohms = 2 x 450 watts)
(Bridged @ 4 ohms = 1 x 900 watts)
(Bridged @ 2 ohms = 1 x 1000 watts)
My question is, should I run this to my Alpine TYPE R SWR-1242D
(Power Handling
Power Handling Capacity (RMS): 500W
Power Handling Capacity (Peak): 1500W)
OR
Re-cone my Arc 15D2 Sub (for $~60-80) RMS power handling - 750 watts
OR
Purchase another Alpine Type R, and Run two...can my amplifier run it? If so in Parallel or series?
Whats the best option?
This is all going into a 1996 BMW 328, not sure if it matters.
I am not sure if 2 Type R's would be under powered by my sub. And also, I am not sure if I would have to get both 1st generation. Not sure if my current one is the older version, but I'd assume it is, since I got it about 2 years ago.
Alright so I have the 500 watt RMS 2nd Generation Type R.
Should I use both Jumpers and have 2 ohms going into the ARC xxk1500 bridged, which will yield 1000 watts.
Is that a bad idea?
Not sure how many watts I should feed to the Type R. I'm going to borrow a friend's voltmeter to measure it out later tonight.
And if its bridged, do I change any of the calculations? I was reading the JL Audio Amp tutorial on gain, and it confused me :S
konradac
SDCrew
konradac
san diego
alxmlr789
vegang
vegang
