Arc Audio KS300.2 Specs:
Power output RMS @ 4 ohms: 2 x 180 watts
Power output RMS @ 2 ohms: 2 x 350 watts
Power output RMS @ 4 ohms bridged: 1 x 700 watts
Transient Distortion (100 watts): Frequency Response: 20Hz - 20 KHz
Signal to Noise Ratio: >98dB
Bass Boost: +18db@45Hz
Crossover (Butterworth): 55Hz - 5.5 KHz variable 12dB
Fuse: 30A x 3
Size: 13.0"(L) x 8.0"(W) x 2 3/8"(H)
Arc Audio XXK 4050 Specs:
Stereo @ 4 ohms: 4 x 50 watts
Stereo @ 2 ohms: 4 x 90 watts
Bridged @ 4 ohms:2 x 180 watts
Bridged @ 2 ohms: Not Recommended
THD %: Frequency Response: 20Hz - 20Khz
Signalto Noise Ratio: 95dB
Separation: >65db
Transient Dist.: Input sensitivity: 250 mv - 2.5v
Bass Boost: +18 db @ 45Hz
Crossover (Butterworth): 55Hz-5.5Khz 12db Stereo
Max Current Draw: 46 amps
Damping Factor: >300 @ 1Khz
Dimensions: 13x8x3.35"
So, I have to select an amp to power my front set of components. I can either select the KS300.2 which can give me 180 watts to each channel at 4 ohms while the XXK can provide that in the bridged mode. So my question to you is which is more efficient and which would you choose. It's about a ~$70 dollar difference between the two with the Ks300.2 being $329.00 and the XXK4050 being $260 new and $220 used.
Fuse: 30A x 3
Separation: >65db
