Arc Audio 2500cxl
like mentioned the sub you have can only be wired to 1 or 4 ohms and if you had a dual 1 ohm sub you can wire to 0.5 ohms or 2 ohms. For you to get a 3 ohm load you would need a sub that is dual 1.5 ohms or dual 6 ohms
I bet with impedance rise in the enclosure, your 2 ohm load will be pretty close to 3ohm if not higher. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
moneyovabreezys
moneyovabreezys
Sac
moneyovabreezys
