Borderline, if you run the cresendo @ 4 ohms & you have good OFC cable you would probably be ok. I'd prob go ahead & step up to 2 or 0 ga. If you run the crescendo below 4 ohms or are using CCA wire definitely use thicker wire imo.
The 1000c4 should be of more concern then the aq750 the 1000c4 is class a/b so it’s less eff plus it has the potential to pull more current then the aq750. Ha the 4 channel is actually stronger then the aq750. Should sound nice though. For the price of the aq750 you could add a few bucks a get a new bc2000 at least then you would re running same manf amps and the bc2000 will just **** an aq750. 1300+watts more than the aq750 for $100 is a smart buy. Just my 2 cents..
