title states it. i need one or the other. needs to be at least. a 3k amp and not audiopoop. i have a few things to trade as well. not just 8 track players loll
i am needing to run 1 ohm but later on will be .5 and i can do that with either of these amps. if i get another db drive it will be 1 strapped if i get a 3500 it will be 1 til i get 2 more subs...1ohm
da fvck you going to fit 2 more subs ati am needing to run 1 ohm but later on will be .5 and i can do that with either of these amps. if i get another db drive it will be 1 strapped if i get a 3500 it will be 1 til i get 2 more subs...
Any idea what impedance they were being run at? I can honestly say I've ever seen an AQ amp blow up...I would only imagine that amp blew cause it was getting a high voltage or the impedance was very lowi have seen a couple but i was told they were the older styles like a few years ago i was thinkin of running them back in 09 and i was warned about them but they have had a newer version since IDK what did it more than likely user error but just my .02. I still think AQ is a great brand and company though
no i dont know what the imp was but like i said probably user errorAny idea what impedance they were being run at? I can honestly say I've ever seen an AQ amp blow up...I would only imagine that amp blew cause it was getting a high voltage or the impedance was very low
I have never really heard of to many issues with AQ amps including the older ones. The reason the 3500 was upgraded was for dual inputs and some other new goodies.Any idea what impedance they were being run at? I can honestly say I've ever seen an AQ amp blow up...I would only imagine that amp blew cause it was getting a high voltage or the impedance was very low
