AQ2200 at .5ohm ?
hey if you need to go .5 on that amp your looking for like 3000 watt right?
I have a stetsom 2k5 that will do 3200 @ 2 ohms @ 13.4 or 13.6 volts i cant remember.
PM me if interested. hope this hepls
Ive had mine at .5 with no problems until i try to turn it up too much. I only have a stock alt and single battery though.
you have any idea what voltage its at when it shuts off ? and how much power do you think your gettin that way?
Ok i cant test it now cause im saving up for the equipment..(upgrading) but im planning on getting a pair of the Hdc12's and i was planning on running them at one ohm using the dual one ohm subs but i seen a lot of posts talking about running the aq2200 at .5 so i was wondering if i should just grab the dual two ohms and running them at .5 for more power if possible... i shouldnt drop below 13v im ordering a 250amp rhino alt. with a 150amp idle current... should i just get the dual two ohms and run at .5 ? or get the dual one ohms and run at one ohm?
jz976
jz976
Michigan
jz976
michigan born
    May 14, 2026
michigan born
    May 14, 2026
