//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gifSeems like the AQ 1200D was designed for that set up //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
200w isn't going to make a difference but i want to say the Aq is underrated also.The Phoenix Gold makes rated power between 1 and 4 ohms whereas the Audio Que makes max power at 1 ohm. Some of those Phoenix Gold amps also benched as high as 1,400 watts RMS!
So it boils down to do you want to run your setup at 1 ohm like every other person on ca.com or dare to be different and run your subs at 4 ohms?//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
The AQ @ 4 versus the PG @ 4 will be a difference. That was the point I was trying to make....200w isn't going to make a difference but i want to say the Aq is underrated also.
Agreed!4ohms is more efficent. but 1200wrms isn't going to kill anything.
