Aq120.4
pro-rabbit
Moderator
Rating: 95%
19 1 0
AQ120.4
New. Only removed from packaging to "mock" up an install.
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
$280 shipped conus
This ready to be shipped same day as payment (if payment is made early enough to get this on the big brown truck).
Will be shipped via UPS fully insured.
pro-rabbit
Moderator
pro-rabbit
OKC, OK
pro-rabbit
