JHardee
Cadillac
yes i wanna power my well its in the **** title so is this to much to push on the bugger? itll be in a 4 cu ported box
I run that daily. Be easy with the gain knob and watch your clipping indicator and you'll be fine. I broke my sub in for a couple of weeks because I'm careful like that. My box is 4.25 @38yes i wanna power my well its in the **** title so is this to much to push on the bugger? itll be in a 4 cu ported box
But the battery you have to run power cable from the front battery to the rear one. And fuse it at both ends. Make sure you connect positive to positive and you can ground it in your trunk.hahhaha man i cant decide, i ask everything!!! luckily you guys are all like pros so it helps with info. umm i could just post another thread about this but ill ask now. how do you buy a battery and put in the trunk and run off your system. is there certain batterys that only work, and how you attack to just your system?
Clipping indicator is a little red light that shows you you're doing it wrong. Call it the n00b light. You'll have to search to get a decent explanation of clipping.what you mean clipping indicator? n for god sake can someone eplain this dang gain knob? should it just be all the way down or what? thanks
what car are you putting this in and what size is the alt?nono i get clipping just didnt know if you were talking about amp going into protection mode. umm another one. if i get the aq2200 and run the second battery, the amp goes off 14.4V... hrmmm what exactly does that mean? will everything work fine buyin the new batt for system?
