OP
hope you dont think you'll be getting that kind of voltage with the MLA module after a load is put on your electrical...i want to see what 2 3500d can do of 15.3 volts @ 1ohm
what meter you using?? in rush current wil throw any volt/amp meter off even in rms mode. it simply averages the output... try again after 2 seconds of play, then measure...17.5V .33 --- 1.3 imp rise
90.5 Volts 69.6 Amps
6298 watts
Strong as shit, had 2 clicks left in volume but it seperated spider. So we will see later how much more we get,
Lower voltage tests to follow.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
i have mechman ext volt reghope you dont think you'll be getting that kind of voltage with the MLA module after a load is put on your electrical...
Also to the OP those numbers make me wanna switch to AQ3500d's..
i wanna hear that!at that show it was 10 12s and 4 3500s 2 sets of AQ comps and 4x90
i wish i had gone today //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifRyan was using 12 aq sd2.5s today on 4 aq 3500s.
Man I seen the most AMAZING thing today I seen a 158 (30 seconds average music) on 3 audioque HDC312s on 4 aq 3500s
God Damm!Ryan was using 12 aq sd2.5s today on 4 aq 3500s.
