dial in a atomic 7000.1
bzb
hello guys
im bas from holland.
i already had an at 7000 but it went broken
a new one is coming soon and i like to know how to dail this amp in perfectly (vac numbers etc.). its gonna be running 1.4 ohm total on two apx 10" woofers. 12v system, 3 battery's,
also i want to know how to make this amp more suiteble for 12 volt
greetings bas
Greetings Bas!
Please feel free to keep me posted through PM's on your progress with the APX 10's. George and Randy have been trying to get me to get them but I haven't seen them last any longer than my AQ's on power like that.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i run a single apx on 0.7 ohm on a at 7000 last year aprox. 6 months, no problem no heat, its al in the box and volume control\duration
sombody has some answers to my questions?
at .75 nominal load mine were set at 3 vac on the bass and 70 vac on the gain. Depending upon your rise you may need to go up or down 5 vac on each burp, the best way is to get on a meter if going for all out spl or like mentioned about using an o-meter. But this should give you a good start.
egg
doesn't anyone of you people in the us with problems concerning this amp?
mine whent with no obvious reason, just turned it on @ normal volume, 10 seconds later no sound and a lot of heat (nothing burned)
bzb
bzb
holland
Mr. Slate
vegang
vegang
