aq 2200 of bl fully loaded will it handle it?
i have questions about this amp. its the aq 2200 or something else. the aq is the best i found so for for the price and what i need. just seeing if the aq can handle the bl fully loaded with out getting hot in short periods of time. do i need to wire my sub to 1 ohm to get all 2200 watts to the sub or should i leave it at the dual 2 like it comes.
also is the aq a mono amp???? i cant find it.... i did see some were it was but it have 2 channels do i just have to bridge it to get all 2200?
Yes its a mono amp. It just has two positives and two negatives. Yes you need to wire the sub to one ohm to get all the power. At two ohms the amp will only put out about half power or so.
fiaudio92
fiaudio92
Eau Claire, wi
fiaudio92
