Anyone work with orion need help
smiley2186
2 orion hcca d2400 2 eclipse sw9122 ti
this diagram i found only show it wire to 1 sub, how can i wire it to 2 sub
I heard that the orion d2400 u can bridged together how? How do I wire up the rca wires it has input and output, master and slave button. My sub are wire up at 2 ohm each with 1 fiberglass box for each sub,”seperate” how do I wire it up to the the orions amp, orion tutorial said something about wiring the negative speakers wire together and the positive together, so how can I wire the amp to the sub.
Okay I bought 2 orion hcca d2400 mono and 2 eclipse sw9122 ti, I want to run 1 amp with 1 sub, how would I wire this up?
im new to this, and new to working with orion, any help i get i appeciate.
You don't have to look at orion diagrams, the brand doesn't matter all subs and amps are generally wired the same way.
The easiest way to run each amp with each sub would be if you had 2 sets of rca preouts on the back of your headunit. Then connect each rca to each amp, run the speaker wires to each sub, and you're done. Not sure why you bought 2 amps, tho as just 1 should power both subs fine.
how does the wire look like is it the y splitter adapter? would u happen to have pics. bought two, amp just to run one each for now, when i located another eclipse titanium i will run all 4, because i have 3 right now, and thanks again. can u do a pic diagram of what u mean?
and i have the alpine 9856 mp3 with alpine g-180 eqaulizer, 2 rca out for the sub and 4 rca out for the mids. how can i change the 2 rca out to make it four, to run the wire back to both amp?
smiley2186
smiley2186
San Diego, CA
smiley2186
NorthFramingham
    Jun 30, 2026
