Anyone with center console experience? Down fire or up?
oxsign
No Affiliation
I'm doing a single 15" in my '05 CC silverado. I was wondering what works best when doing a box like this? Down fireing, up, port down, up, forward, etc. Just trying to pick your brains for info. I'm at around 3cubes after displacement with a 6" areo. The sub is a ssacket recone for my omega. I'll have around 1500-2k for it. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
If you have fiberglassing skills then you could do a design like that one and fiberglass the hole bigger, but that's if you can't fit a fifteen in the center console space. I saw one not too long ago that was sub and port forward but dont' remember where.
I wish I did have the skills, lol. I just don't have the patients to do it.
good luck with a 15". do a 12" ive had one and loved it
Had a 12" moving to a 15" now. I have the room no problem, just trying ti figure out the best possible way to fire everything.
no way to do a 15" there, I was going to do a beefy 10" in mine then never did. If you have a crew cab just take the 2/3 seat out if you don't have a lot ppl ride with you. Thats what I did and put my 18, there all my amps mounted on the back wall..
I guess I should clear things up a bit. The rear lower seat of the 60/40 bench has been cut down to 2 buckets. The console will be in the back between the back of the regular console and the seats. This is what was in there before.
I'm now doing 1 15" cause I didn't quite have all the airspace I needed to do the 4 12". So the factory console is back in and i'm now going to do a single 15" with plenty of space to spare.
Sorry, but I didn't take any pix. I just stripped it down to the frame and took some measurements and went from there. You will have to weld a bracket back when all is said and done though.
oxsign
No Affiliation
oxsign
Orlando, FL
oxsign
