Dr. Dan
Doctor of What????
Rear fill is not really an accurate term here, more like little midbass subs firing into the cabin. Of course the ideal situation is to have your front drivers do as much of the reproduction as possible, but with the proper crossover points, I think this could sound pretty good.
For example, I'm considering a set of Morels that have beautiful midrange, but also lack lower end extension. I drive a small stick shift coupe and there's no chance of fitting kick panels on the driver's side.
So how 'bout using the morels upfront, and putting some deep midbases from Seas, Adire etc... in the rear shelf. If the Midbasses are crossed to produce just a narrow band, perhaps somewhere between 60 hz and 160(just guessing) I wouldn't expect any negative impact on staging. Frequencies that low are still pretty non-directional, and I bet it might blend pretty well with my 12" sub in the trunk.
Basically this would be like a 3 way system with the midbasses in the rear for ease of installation.
Thoughts?
Thoughts?
